who's been having to add transmission fluid?
Old 10-09-2017, 01:05 PM
mchertel's Avatar
mchertel
mchertel is offline
Originally Posted by stixvrad
That's how I'm looking at it too. The thing pulls great between idle and 4 grand even two up. It just seems pointless to wring its neck. Its actually one of the reasons I went from a high revving sport bike to an HD bagger. To chill.
Right on. I didn't have a sport bike but I did have a 2012 Kawasaki Concours which was pretty fast but not at all as comfortable for long rides or for my wife.
  #1892
Old 10-09-2017, 01:21 PM
$tonecold's Avatar
$tonecold
$tonecold is offline
Received 1,748 Likes on 935 Posts
Originally Posted by 103Eagle
October 7 Update:
Service brings bike back out and I was advised that the MOCO has no fix at this time and need to return every 1000 miles for fluid checks and adjustments till further notice. Tech visit no longer scheduled. This info was after service called for guidance......... Gee, so if you take a long trip you need to find a dealer every 1k miles for a service??? Not the answer any of us were looking for and sure does not give me any confidence in the MOCO. Seemed as though the dealer service was as surprised as I was with the MOCO answer........
Like to hear if anyone else gets this answer on your next visit for oil transfer problems..............
Eagle Out
So does this qualify you for the lemon law in your state? You're one of the people on this thread that I think would be looking at that pretty hard. MotoJockey and Steve Cole are a couple more that don't seem to be able to use their bikes to any satisfactory degree. I think that makes them lemons.
103Eagle (10-10-2017)
  #1893
Old 10-09-2017, 03:05 PM
RK14SGS's Avatar
RK14SGS
RK14SGS is offline
Default Dyno
Originally Posted by mjwebb
I'm not sure that would be the most effective test. Steve Cole has reported consistent, repeatable transfer issues and at one point indicated that 5000 rpms for 5 minutes in 2nd gear oughta' do it.
I just couldn't ever allow my bike to go through that so will just take his word on it..but your idea would be a less tortuous test to try and establish a baseline..if it does transfer then you could reasonably project it could worsen pushing further and good enough to validate the problem exists on your bike..which is all you're trying to establish anyway
MJ.. your bike was dyno tuned at the dealer. They took it to 6k multiple times. Your dyno chart shows they stopped the pull at 6k. Did you by chance discover this low fluid condition after they had put it in the dyno? Was your low levels after tuning?
I ran mine up to 5500 during my data logging. That's when I noticed my transfer. Both of our bikes would have seen similar conditions like Steve Cole on that it was run up to near red line.
Just curious...
  #1894
Old 10-09-2017, 03:35 PM
mjwebb's Avatar
mjwebb
mjwebb is offline
Received 8,608 Likes on 4,455 Posts
Just curious...
funny you mention that, after beating on my bike really hard this Spring, after having a stage 1 installed over the Winter, then going thru with the dyno tune and commencing to beat on it some more, is when I did the random fluid check and noticed the low trans fluid and decided to throw it out on this forum because I thought it was unusual without an obvious leak for the trans to have any opportunities to 'consume' fluid..at that time consume was all I could think of because transferring wasn't something I had heard of in this regard
  #1895
Old 10-09-2017, 06:00 PM
harrell42's Avatar
harrell42
harrell42 is offline
I have had a 2011 ultra imited with the 103 engine and now have a 2009 tri glide. I have been to dealer many times with this problem, dealer does not know what is going on and has never hears of it before(strange reply, or they all do it which is true in this case I think.i would sure like to have a fix for it I like to run my tranny a little overfull makes it shift much better but it is definitely going into the primary.
roller
  #1896
Old 10-09-2017, 06:04 PM
harrell42's Avatar
harrell42
I ride my bikes about 2500 rpm all of the time and never exceed 3000 on shifting maybe 3500 sometimes it does not mater what speed you drive
roller they both transferred tranny fluid into primary
roller
  #1897
Old 10-09-2017, 06:40 PM
psyshack's Avatar
psyshack
psyshack is offline
103Eagle, I'm really sorry to read your post. But does not shock me at all.
  #1898
Old 10-10-2017, 06:15 AM
fwj's Avatar
fwj
fwj is offline
In the German V-Twin forum some are reporting that the migration has stopped after changing the clutch pushrod to a larger diameter version of a former CVO model. Bellow the replacement parts:
11143 Retaining RIng
37909-90 Retaining Ring
37092-06 Clutch Release Rod
37000113 Clutch ROd End
37000112 Pushrod , Clutch Release Plate
Anybody here having solved the migration issue with replacing the parts listed above?
The following 2 users liked this post by fwj:
$tonecold (10-10-2017), lp (10-10-2017)
  #1899
Old 10-10-2017, 06:57 AM
ocezam's Avatar
ocezam
ocezam is offline
Interesting.
My wife speaks German, can you give me a link to this thread?
  #1900
Old 10-10-2017, 07:27 AM
dceggert's Avatar
dceggert
dceggert is offline
In the meantime while waiting on an official fix there is one thing that those with the issue may be able to do. In the auto business when something like this comes up the team charts commonality between the vehicles with the issue. So, what things do all of you experiencing this issue have in common?
- all bone stock? Stage I, II, or III?
- air cooled, twin cooled?
- ride easy, ride fast, ride like you stole it?
- hilly countryside, flat, city riding, mostly highway?
Not that this will fix anything but it may lead to a clue as to the root cause.
TomcatCV62 (10-10-2017)
Quick Reply: who's been having to add transmission fluid?
