Heat issue for passenger
Took the wife for a ride yesterday for the first time on my 2017 CVO street glide. She complained that the heat on her right foot was 25X worse than the 2008 Ultra I had previously. Surprise given the exhaust ports are water cooled coupled with oil cooling. The right floorboard isn't even close to the header pipes. I can only assume that 6 inches below her foot is a catalytic converter which is producing the heat. Anyone heard this complaint from a passenger? Opening the vents on the lower fairings helped a lot, but it seems to me the only viable solution is aftermarket pipes. Would love to hear some comments.
think you're correct about the cat proximity to her foot..there's a few things you could do..buy the cool flow fan and mid frame deflectors but that isn't pinpointing the ankle area heat..put the SE High flow exhaust system on which has the cats relocated in the mufflers further back behind her foot..or go with catless headpipes, but after you purchase and tune all that and kick your warranty to the curb the expensive SE exhaust might not sound so bad especially if it mitigates or eliminates the problem, but doubt it'll be 26 X's better than your 08..:-)
I know it may not look ideal but has anyone tried wrapping the cat area with thermal exhaust wrap? Its meant to contain the heat.
https://www.heatshieldproducts.com/m...cing-pipe-wrap
I've used it in the past for sportbike headers. Works well at keeping the heat from melting fairing parts when they are close. As for discoloration, well, if you keep it wrapped, I guess whats the difference if the factory cover gets discolored. Its covered by the wrapping. When you wrap it correctly it doesn't look all the bad too.As for tuning, it shouldn't have any effect on that. If anything it should help make the cat perform better by keeping it as hot as possible.
