Service bulletin M1450
Thank you Steve Cole for that. It seems that the part number for the oil pump that has been floating around for a little while is not the part number that this update is suggesting. 62400178 doesn't seem to be a good part number yet. Oh Joy... my motor will stay two pieces for an undetermined period of time
Yep, this is exactly what happened to my 2017 CVO Limited with Stage 4 kit. HD express shipped a new engine to my dealer for installation. They are also covering the costs for parts and labor to re-install a new Stage 4 kit on the new engine once the kits are released. Its also worth noting that if the rods and crank are stiff and the engine is being replaced, they will also ship a new oil pan to ensure no debris from the failing engine contaminates the new engine. I'm picking up my bike with the new engine tomorrow. https://www.hdforums.com/forum/milwa...ddressing.html
Here is a list of all the part number oil pumps I have seen so far on the M8 engines
62400119
62400122
62400121
62400124
62400143
62400146
62400178
62400182
Also a picture of a 62400144 but I am sure there are others out there floating around too.
62400119
62400122
62400121
62400124
62400143
62400146
62400178
62400182
Holy Guacamole! started out as 2..guess that 1.5 million miles and 7000 hours of accelerated dyno testing just wasn't quite good enough
PilgrimsDad (07-13-2017)
Just saw this job posted and thought it was for this very thread
Sr. Project Engineer - Lubrication, Breathing, and Cooling Systems
Harley-Davidson - Wauwatosa, WI
Auto req ID: 4996BR
Title: Sr. Project Engineer - Lubrication, Breathing, and Cooling Systems
Job Function: Engineering
State and City: Wisconsin, Wauwatosa
Company: Harley-Davidson Motor Company
Full or Part-Time: Full-Time
Shift: Shift 1
Job Summary
At Harley-Davidson Motor Company we do much more than just build motorcycles; we fulfill dreams of personal freedom. We are customer led in all we do, and we believe and invest in our people and our communities. Harley-Davidson believes that its people are the only real long-term competitive advantage and their energy and commitment is what has made us successful since 1903.
This Engineering position will be working through the full lifecycle for projects related to cooling circuits, lubrication/oiling, and breathing systems. They will be working on current and future state projects where their technical expertise will be heavily relied on by internal stakeholders. They will work through the design, development, and implementation into production for components related to cooling, lubrication, and/or breathing systems within Harley-Davidson. They are considered to be the “subject matter expert” in engineering for cooling technology, lubrication/oiling, and breathing systems.
More specifically this role will be responsible for:
- Implementing system strategies and technology roadmaps for integration across the H-D powertrain/vehicle portfolio.
- Connecting business strategies to support the cross-functional engineering needs for engine oiling, cooling, and breathing.
- Developing and articulating best practices that use standardized engineering processes/ tools
- Creating and managing a "virtual shelf" of proven cooling technologies, lubrication/oiling, and breathing systems that are world class products.
Although the Senior Project Engineer does not have any direct reports, they will be a consultant and coach for internal employees. This role will be influential in moving from current cooling and lubrication technology to future state systems that will help propel Harley-Davidson to creating the next generation of motorcycles. This role has the growth opportunity to develop into a future leader for H-D across the company.
Education Required
A Bachelor’s Degree in Mechanical Engineering or related technical area is required.
Experience Required
Position requires 5 years of hands-on engineering experience specifically related to designing and implementing powertrain systems and components.
- Experience working on Cooling Systems is required. Working knowledge of Cooling Technology and Circuits can include; heat transfer, pump design, fluid dynamics, pressure monitoring, and coolant/air flow through the system.
- Experience working on Lubrication Systems is required. This experience can include; heat transfer, chemistry of oils, durability, filtration, testing methods, and pump design.
- Expert level knowledge related analytical or empirical tools (i.e. GT Cool, Thermodynamics calculations, Fluid Dynamic calculations, FEA, Weibull)
- Experience working on Breathing Systems is strongly preferred, but not required. Knowledge should be surrounding CFD, system design, and testing methods
Auto req ID: 4996BR
Shift: Shift 1
Job Summary
Education Required
Experience Required
