Weird idle after bike gets hot
I have the button on my left side, but it doesn't do anything to show the EITMS status.
I can see whether it's turned on by "reverse rotating" the throttle, but I don't see any way to tell if it's active at idle.
I went outside to check if it was on, turned key on, rolled throttle forward and it was green. I'll ride it again and get it hot and see what happens. It sounds like what you guys are describing. It doesn't make a whistling noise, but more of a little bit of a sputter. Rpm's raise a little bit..
You have the option to turn it on and off at will with the throttle rolled back and wait for a few seconds. Green is on red is off.
Bob
and when you take it to the dealer for 1K take the long way there and get it good and hot, have them come out and go thru enabling and disabling it in front of them..it'll be obvious when it switches on and off and it does jump up in idle rpm's when enabled..I'm guessing tho everything is fine and normal with your bike and working as designed..good luck
