Oil Level weirdness
It really sounds like it's overfilled. When COLD it should NOT read full on dipstick - it should only be halfway between add and full.
Proper procedure is to check it at ambient temperature and make sure that the level is halfway between 'add' and 'full'. Then, get the bike to operating temp, which is around 10 minutes of riding, then let the bike idle on the jiffy stand for 1-2 minutes. Shut it off, check it.
I find that idling on the jiffy stand allows the oil to drain down into the pan after riding. My level is different if I park the bike and immediately check vs. idling on stand for a couple minutes then checking.
I've always checked my oil when the bike is cold & usually it's in the middle but after reading some of these posts decided to check it hot, let it idle for a couple of mins then checked & it's at the bottom of the hatched markings, does that mean I need to add some ?? Mebe I'm just getting paranoid now
paullavery (07-21-2017)
Maybe off topic, but wife's 2012 tri had the oil changed at an indy. Was up to the full mark, cold and says that on the dipstick if level. Ride it and noticed oil residue on r/s fender. I drained out to half on dipstick and good to go, no more oil residue. I change oil myself days ago and put in 3.5 quarts and its on the full mark, so again I drain some to half stick. I look in the owners manual to verify first before I did the first drain some time ago. I'm totally confused by this as well. Took my street bob for the first service about 2 months ago and noticed when cold its full on the dipstick, but according to the manual it's not supposed to be, only when hot. Called dealer who did service and was told they all take 4. I have kept an eye on the residue, so far none, but figured its under warranty and I made a call to dealer and was told different, so let HD eat it if something should come up. A friend of mine who is a long time HD guy told me that at half stick it takes a quarts to the full line, I beg to differ, so now I'm wondering if the tri is sumping ?
Finally got some news on this. The dealer spent all week riding around in the heat to see if they can reproduce my problem. I went to pick it up because they didnt have enough time to put more miles on which is understandable. Ill rode it and monitor. As I went to the bay, the mechanic said give me a few more minutes to check something. He had just got back from a ride on it. He pulled off the primary cover and the oil over flowed out. He said, I think I found your missing oil problem.
They did a oil change on Saturday to make sure the levels were correct and said I had only 3.5 quarts in there. Now, before I rode the 20 miles to drop it off, it was over full.
Have an HD reference number, got a loaner (RG Ultra) and now have to wait for HD to tell the shop how to fix this so called impossible problem.
