Rattling noise
Rattling noise
Recently street glide special developed a rattling noise on starting that disappears after about 30 seconds. Sounds like a heat shield is loose but checked and all are tight. Completely disappears after a few seconds. I was wondering if anyone else has experienced this? I'm trying to avoid taking to dealer as I have slip ons and don't want to switch back unless I have to. Slip on is not the problem as I started to hear the noise prior to changing pipes. Just a slight rattle but noticeable. Any ideas??
Thanks
Thanks for the reply. Just for clarification both of you are referring to putting a washer between the hanger and pipe it supports .
this is the hanger that supports the crossover pipe located under center of the bike. Your reply sounds like my problem as I've tightened everything else in the system. Thanks again I'll try
Quick tip- if you can grab the left slip on tip and move it up and down, the crossover clamp is loose.
Plus, in my admittedly short time as a Harley owner, I think their "service advisors" are highly lacking in mechanical aptitude. I've already been told some dum-*** things in two service visits.
Lifter
don't think so but anything is possible. Don't happen every time and seems to be coming more from the pipes than motor. I'll monitor. I did drop a washer in and tightened the hanger. Sound stopped for now. Thanks for the info all you may have solved the issue.
The following 2 users liked this post by sixguns:
Michaelpost (07-23-2017),
RoadRunner13 (10-28-2021)
