tuning advice from an expert
Your guy is like correct about the increase in power.. 3-5 sounds reasonable..
1. The timing can be adjusted range is limited.
2. You can tweak the AFRs indirectly in the open loop sections by changing VEs. Again range is limited.
3. AFR table is fixed so that the closed loop sections cannot be changed.. IF you look at the WOT sections the AFR is set to 11.7 witch is pretty rich..
I've tuned a few with the Street tuner. I have yet to have one that didn't get maxed out in the VE's and want more change, even using all HD parts. The Street Tuner is what it is. I have a 2017 Dyna coming in next week for a tune. Dealer sold him the Street Tuner and I sold him a TTS Mastertuner. I'll tune it with both tuners and post the results.
It wasn't running an SE exhaust..
I've ran out of adjustments tuning a M8 with the Street Tuner (even using all HD parts and the Street Tuner MAP for the build). Only difference is I didn't re-tune any of them with an aftermarket tuner.
Too bad about not retuning with another tuner.
