New Screaming Eagle Pro Street Tuner software
For those of you who are interested, a new version of the Screaming Eagle Pro Street Tuner is now available from Bosche Automotive and the Harley Davidson Motor Company. By launching the software it will check to see if updates are available and then download the newest version. The newest version is StreetTuner 11.000.007exe. Hopefully it will provide some new fixes to the ECM program. Note: in order to use this software to tune your engine you will have had to have purchased the SE Pro Street Tuner and have it married to your bikes ECM. You will also have to install the software on your laptop and purchase two cables which hook the tuner to your computer.
Many have already purchased this tuner if you installed the Stage I air cleaner and/or Screaming Eagle slip on mufflers to your 2017 motorcycle or the new 2018 motorcycles. This software only works on the Screaming Eagle Pro Street Tuner not the older versions. I can not say what changed are new because I only found the update earlier today. Within the next few days I will be retuning my 2017 and also doing a couple of new smart tunes as well. Will know more then.
bpav16 (02-11-2018)
are you saying they have superseded this with a new one, or just new s/w updates are available with it? reading your post can't tell if you're talking about a new hardware device (SEPST) or just sw updates..
https://www.harley-davidson.com/stor...ance-tuner-kit
this is till out there pending regulatory approval
"https://www.harley-davidson.com/store/smart-tune-pro-automatic-tuning-module"
From looking mainly at the stage 2 touting TQ map..
The only things I see are that they added a 3500 rpm adjustment to the throttle progressiveness table. The new throttle tables are a little more They also give you the option of setting the rev limiter lower then 6400 (in the stage 2 map anyway)..
Idle RPM table is not viewable.
Everything else looks the same but I've not looked at other maps..
Most of the VE and timing stuff looks the same..
The new softail stuff has been added in..
not following..."a new version of the Screaming Eagle Pro Street Tuner is now available from Bosche Automotive and the Harley Davidson Motor Company"
103Eagle (09-05-2017)
OK, I can see where there might be some confusion here. Bosch Automative and the Screaming Eagle Division of Harley Davidson Motor Company have just released their 2018 version of the Screaming Eagle Pro Street Tuner SOFTWARE. When you hook up your bike to the computer using your VCI it will automatically install the latest software updates on your computer as well as update your VCI (the tuner) if it needs it. If you want to take advantage of the new ECM updates you will have to re-tune your bike using your tuner. Note: You must have an internet connection to get the updates. Sorry for any confusion.
1. If dyno tuned, it's probably best to leave it alone unless doing any changes..
2. You don't have to be hooked up to the bike to get the update.
3. From what I can tell you won't be able to make any changes with the down rev software as to check for the latest rev. It wants to be connected to the net to see it what the latest rev is.
4. You don't need to retune but need to copy the modified tables from you current tune to the map that come with the new software.
5. It my guess that they likely made changes to the map that you can't see in the user street tuner software..
It looks like harley's dyno charts show the runs going up to 6250.
I have a 19' m8 114 with a stage 2 kit and a SE tuner. The dealer installed the stage 2 kit and tuned the bike and it ran great for about 500 miles then started to run poorly, loss of power, vibration, sounds muffeled, etc. My question is this, is it possible the bike lost the tune? Should I try to flash the bike? Would that likely help? My dealer is 3 hrs away so looking to fix it meself. TIA
