Question on Stage 2 or 3 for M8
Hi all. I put down a deposit for a 18' SG and it won't be in for awhile as it is an anniversary model. I'm going to have the dealer do the Stage 1 for sure before I take delivery, but wondering about the Stage 2 or 3 depending on which one I decide on. I would like to gather some opinons on whether I should do the stage 2 or 3 upgrade before I take delivery? Or wait and have it done at the 1000 mile service?
I wouldn't waste time with the Harley stage kits beyond maybe the stage 2 torque cam while the bike was under warranty. You get an increase just not what you would from a good head porter and after market cam for the same or less money. If it were my money I would do the stage 2 and after the warranty is up look at who is making good broad power in the aftermarket.
If you were going stage 3 or 4 I would do it before delivery and break it in once.
That being said I have a hot rod built motor that I ride when I want to wick it up and the stock stage one 107 is not a slug. I am leaving mine alone.
The stage kit you go with is up to you, the Videos Harley has on their stage kits were helpful to me when I had to decide. What I will say is to have it done before you take delivery. especially if your going stage III, because there have been no heat cycles, nothing to cleanup and everything is new all at the same time.
I have the stage 2 and am less than impressed. I understand the torque cam, is "EPA" so HD says, but my dyno run was 92/107. That doesn't trip my trigger at all. I'm seeing other folks, Fuel Moto, TTS and others posting triple digits on HP and 110-115 on the torque side. I would say save your money. Decide what you want you to do on the warranty bit and get real motor work done, if thats the route your headed. Just my 2 cents.
since you are doing the Stage 1 right off the bat regardless, and is prerequisite to further Stage upgrades, and if going SE just do the ECM recalibration, I'd ride it that way until close to the 60 day expiration for SE upgrades still under warranty..you may just like it enough to stop there..I did, except had them dyno tune with SESPT for even better performance.
doesn't sound like money is a concern and if you just want a ball buster then go Stage 4 under warranty..can't imagine that would feel underpowered or not perform great for the vast majority of people and you don't have the headaches of trying to tune with an aftermarket tuner and parts and kick your warranty to the curb..my biggest concern would be doing a Stage 2 and not being satisfied, then do a 3 and regret just not going all the way and have wasted time and money with incremental upgrades
all starts with the first question, what are your intentions on how you want to use this bike?
good luck
What I did, and what I recommend, for any M8, is that if the Harley sound is something you want in your new bike go straight to Stage2. Just doing a Stage 1 on these bikes for me doesn't cut it in the idle sound department.
Whilst a M8 won't ever sound like an evo, doing the cam too will give a nice improvement. My result was 97/109 which gives the bike a great ride experience but it also sounds killer.
The following 3 users liked this post by Oz Dan:
Asking cause I think I'll wait till my warranty is no longer a concern, then do the cam upgrade.
Yes I think that's a good assumption. The tune is important, as is a catless header. In Australia we still have access to the old SE tuners and with a dyno the actual Harley cam sounds great. Goes good too.
