Fueling oil pump
My bike had the cylinders over bored from the factory with almost no visible hone marks. In braces the front jug was .006" over and the rear .007". The rings were still seated when it was taken down. No excessive blow by on my 107. But the piston slap was massive.
Couple that with good pressure from the oil pump but what appeared to be low volume. The bike has been a can of worms. The pressure is always good. And I've done a massive amount of testing to prove that. But it's like the volume of oil pumped is very inconsistent. This can be heard in the valve train. Good oil flow and the rocker to valve stem interface is very quiet. Then volume drops and the rattles and harmonics come roaring in. Then back to quiet. The whole time the pump is showing good psi in the 30 to 34 psi range on a fully warmed up engine. And at idle it's 12 to 14 psi. The bypass opens at 45 psi like clock work and maintains 32 to 36 psi while open.
Come on new oil pump.... I need you.
Kyle Moore (11-20-2017)
Sorry I don’t see it. An M8 107 with a Cycle Rama 460 (ac and exhaust) will make torque in the 115 - 120+ range. The Wood charts on the 117 aren’t that much better. I think I would wait a while. When the aftermarket figures this motor out you’ll see way better performance than that. The M8 has potential. A TwinCam 117 will make in the 130’s on both sides.
Once I started buying oil pumps and installing them in my friends Shovels, Evo's and twin cams it became clear very fast that HD pumps were mass produced junk and tolerances all over the place. Not to mention they cost more at your local dealer. A basic S&S or Feuling pump was always a better option then even a HD screaming turkey oil pump. The S&S pumps were pretty much the standard. But the Fueling pumps had a much better finished look. There machine work was down right handsome. And this coming from a guy that was raised in tool and die shops.
I laid out on my bench once a HD screaming turkey pump, S&S and Feuling. All for a 103 twinky. The HD pump was like a over priced colt .357 revolver. The S&S was like a proper Large frame Smith & Wesson .357 from the late 1930's. The Feuling pump was like a Fine Korth .357. With the later two costing less that the idiot HD part...
Feuling made it's name with me with parts to upgrade OEM HD oil pumps. For many years the HD pumps made plenty of oil flow but lacked in pressure. Something as simple as a spring for the bypass valve made all the difference.
