First impression: Hog Leverage adjustable clutch lever
With all the fancy crap hanging off the clutch perch, I decided to let the dealership install the adjustable clutch lever I got from Hog Leverage. They were going to replace the clutch-side control module, too, but didn't have the parts in stock.
First impression on the new lever, based on 20 minutes or so riding home:
I didn't spend a lot of time slow-driving, but the initial impression is that the lever will let me feather the clutch with a lot more comfort. I just took the Ride Like a Pro a couple weeks ago, and I'm still spending a fair amount of time practicing, so it's just a matter of getting used to the new lever.
Based on the short ride home, the squeeze pressure seemed to be a lot lighter.
I'll update this after the weekend's rides.
- The finish is good, and the lever appears to be well made, and solid.
- The adjuster **** is also solid, and the adjustment is clear and firm - no wobble at all.
- At max adjustment, the lever squeezes all the way down to touch the grip, but the clutch disengages 1/2 - 3/4 of an inch from the grip, so there's plenty of clearance.
- At minimum adjustment/longest throw, the lever sits a little closer than the stock one.
- At all settings, there's a little slack - almost like an old-school cable clutch with some "play."
- There's also a little "negative play" at all settings - I can push the lever away from the grip at all settings. I'm a little concerned that the spring may not last, but we'll see.
- The lever isn't as long as the stock one, and the shape is squared off a bit more than stock, so the lever feels a bit square on the fingertips. I use the end of the stock lever, so I'll have to learn where to position my fingertips again.
6113_ (11-24-2017)
You just described the perfect clutch for me. Anyone know how to change or swap a mechanical clutch to get that result?
Received 14,658 Likes
If you came from a 2001 the new clutch probably feels light ha!
I didn't come from an 01. It is just the bike that I can't let go of. Had a couple other Road Glides before I got this one. But I do have a Barnett Scorpion clutch in this old bike. Can't remember the spring configuration but lighter than heaviest.
