no more actual oil pressure readings?
Sooooo... on the info screen of the boom audio, when you thumbed the switch to get the oil pressure on my '15, you actually got a numerical oil pressure reading.......now on my '17, when you do the same it just says "OK", or "check oil".....no PSI readings anymore...... After a few bullshit answers from some dealers, I finally got what seems to be a credible explanation from one dealer,(Thank You Black Widow Harley in Port Charlotte, Florida). It seems that the '17 up sending unit is the culprit ....I was hoping it was just lost in the ECM and a flash would bring it back,(like the one that keeps your side driving lights on with the center high beam). The service manager also said that Harley is aware of it and it happened with a supplier change....(probably 7 cents cheaper)......... he claimed that they will have one available at some time in the future that can be changed out and return the PSI feature..... he didn't know when or who would foot the bill...... every time I look at it, all I can think of is Buckwheat on Spanky and our Gang saying, " ooooooo-TAY!....... Don't know about you but I sure prefer and actual readout over the "OK" or blown up option??????Anyone else tried to get an answer out of a dealer about this? Usually with HD more noise = faster results...... thanks....DW
Maybe they thought that an indication of zero pressure from their POS oil pumps at idle would upset people?
Just a guess...
That explanation from Black Widow HD is just their theory as to why there is no pressure reading on the 2017-18 touring bikes.My quess is Moco knew the M8's had pressure problems and eliminated the read out. I wouldn't hold my breath for a quick fix from Moco.
psyshack (03-04-2018)
Oh...... And I don't ride "most" motorcycles....................... DW
With MoCo products, all bets and assumptions are off.
Randol (03-05-2018)
Certainly better that an "OK" or "your screwed".......DW
Need has nothing to do with it, (as with most things in my life)... I want one..... there is no way to know where the pressure is running without one, and I like to see that I don't have any minor changes from "normal", which experience has shown is a good EARLY indicator that something isn't quite "right" but hasn't gone "BOOM"....yet.....
Well, ok, but promise us you're not gonna come on here like Chicken Little hollering about oil pressure issues when you only see 6 psi at idle on a hot motor.
