Expert guess/analysis needed
Heres my M8 OEM cam. 1500 miles, oil pump failure, over bored cylinders. But dont even look at the wear pattern on the lobes. How about the third world assembly marks cause the idiots don't have a clue how to press the lobes on the shaft and the sorry *** wear pattern because they cheap out on the cam bearing. Thats third world right there. I've bought and paid for my thrid and last Harley. It's a freaking shame.....
A M8 nesting wishing it was a real motorcycle with real engineering and production. All thats missing is nitting needles and mud flap ****.
Then wipe all the negative thoughts that have been planted in your head,and just Ride!
The following 5 users liked this post by Peter Quinn:
Another Old Timer (03-17-2018),
Cogswell (03-20-2020),
lh4x4 (03-19-2018),
LoneWoolf (03-17-2018),
Tinker55 (03-17-2018)
The scratch marks on the lobes are more than likely environmental damage. IE silicate, dirt, carbon and such. It could also be caused by production debri left in the engine. But those cam lobes are really pretty hard. They have clearly been heat treated then finish grind applied. OR scratches applied during final grind. My lifter rollers do not have corresponding/matching scratch marks on them or pits.
Our OEM cams really are not that bad as HD OEM cams go. It appears your was assembled a lot better than mine.
Sixguns cam is a true mess.
Just had a ride today on my 114 Heritage with the Torque Cam installed. The Rev limiter hits solidly at 5,600 RPM. Tried it twice today in 2nd gear.........WTF. The Torque Cam SE flash is suppose to up the Rev limiter to a higher #
I am going to take it in...again for a supposed 3rd Reflash....
lh4x4 (03-19-2018)
