First Oil Change Surprise
Just did my 1K fluid change (17 Limited) and was surprised by what came out. First off, oil appeared a little dark with very little metal/crud on the oil plug. Transmission about the same except a lot more metal/crud on the trans plug. Now the primary, the fluid looked very milky and there was a considerable more metal/crud on the primary plug. I have never seen primary fluid that milky. Is this because MOCO used Formula + or is something else going on?
One more issue, I expected to get more than 5 qts out total of all fluids. I barely got 5 qts.
Don’t US dealers do the first service free of charge? Over here, if we touch em, unless a qualified mechanic, end of warranty. There again, we can add catless headers, any mufflers, any tuner and warranty remains intact. Nuts.
I’m guessing your dropped oils look weird because it’s being run in. Bike running ok?
Engine oil sounds normal.
Trans sounds normal also. I would not expect to see much crud after this though.
Primary will usually have lots of crud on magnet. Milky may be from sitting so much and having water from condensation in oil.
I don't know capacities on the M8 bikes.
Received 32,998 Likes
I'm sure we all wish the first one was free.... You can sometimes negotiate it for free when you buy the bike... But its usually $300 plus.
My guess is you changed the fluid while the bike was cold, or at least not run long enough to evaporate the condensation that accumulates in the oil, thus the milky look.
I always change mine after a days ride. Not necessary but if you drive it for 30 minutes or so it should evaporate the moisture.
