code C1021
code C1021
Changed out my front wheel to chrome ,installed new bearings(all *****) and installed now ABS light stays on and diag code is C1021 C1021 ABS front WSS always zero.I know bearing is in right place and I have reset it 3 times but it comes right back.Thanks for any help cause I know dealer will say its my fault and charge me.
Pretty good info and perhaps a solution for you here.
http://www.harley-davidsonforums.com...heel-21-a.html
i hate to say this but replace the ABS side with the OEM bearing. i did the sam thing on my bike and realized that the aftermarket bearing has a smaller surface area for the ABS sensor to pick up. compare the aftermarket ABS bearing to the Harley ABS bearing and u will see what im talking about. i changed mine and no more ABS error.
see pic
Harley has updated the wheel bearings as I was told during a recent front wheel bearing replacement. It did look different than the old style bearing. Sounds like you have the abs bearing in the wrong side of the wheel, facing the wrong direction, or damaged it during installation. Of course that applies as long as the sensor pickup and wires were not damaged when you changed out the wheel. Tire size and diameter did not change a thing on my 09 when I put on a 21, the stock was a 17.
