Clutch Recall Video
#31
The one thing that I found in the video is that if a person has done "The Fix" the actuator housing with the hole drilled in it will be reused and the primary will still be vented. I think I would warn them of the modification before they do the recall work so they don't think it is a defect.
Max Headflow (11-16-2018)
#32
Too bad it happened but I love the easy fix!
#33
#34
Mine was done this morning right on time. They do replace the Fluid with the new PLATINU Brake fluid. They did remove sidecar body to get at it. Road it about 100 miles in 26 degree weather noticed no difference. Works as it should.
Bike came out alot cleaner than it went in. I rode it there in snow.
corliss@bakerdrivetrain.com
05-22-2017 07:44 PM
j14woods
03-18-2013 11:06 AM
