Tpms
#31
Tpms
Congratulations Sven, I’m sure you helped quite a few doubters about this working or not. Since I see no “notch” etc. that the dealer has mentioned, I believe you proved it can be done. Now to see the tire mounted and the display on the speedo and on the Boom GTS working would be the cherry on top. I hope to do the same on my 2019 SGS when I need tires. Thanks!
Howard
Howard
#32
#35
#36
#39
It’s the same thing like the GTS.
They could get working it on older models but they don’t do that. It’s only blocked by the GTS software.
You can see my photos and that the sensor fits. And you posted a photo of a CVO Wheel which looking exactly like my valve hole. And you still have doubts because you blindly trust what dealers say.
It fits on my wheel and there are some aftermarket system too with the same Sensor. Like Tire Watch System which fits too on Harley’s.
You can blindly trust your Harley Dealer.
I did the same mistake. They are good mechanics but they are dont good in electronics Knowledge.
#40
The CVO wheel doesn't look like yours...there is some type of bracing at the hole...it's there for a reason....I'm not an engineer so I don't know why.
Just because the sensor "fits" in the wheel doesn't mean it will function properly.
I'm NOT blindly trusting my dealer, as a matter of fact they never told me it wouldn't work. They only told me that both the radio and the gauges have separate turn on points for TPMS and they both CAN be turned on. The tech I always talk to about this type of stuff said he did it on his own bike, but that's s far as he went,
I understand the electronics part....I have working front to rear wired comms on my 2019 Road Glide Special that it isn't supposed to have that I personally put in it. I use it every time my wife rides with me. So it is fact that it can be done.
As much as I want this TPMS to work right now it is just theory with some unanswered questions. One being, what is the reason for the bracing on the inside of the rim on the CVO wheels for, and the second is, will the radio/gauges actually read the sensors once activated.
I'm pulling for you to get this working, it's just that I'd like to know all the answers before I commit time and money.
