Do large diameter mufflers hurt low end ?
As several here noted it's not the size of the muffler body, it's the size of the baffle. Baffle size & design greatly influence & affect the overall power curve, baffles that are excessively large affect low RPM performance, response, and tunability. The M8 engine is also more picky on what it wants compared to Twin Cam. The standard 2.25" louvered baffles in the Rinehart mufflers work well in most applications, the mufflers that typically cause issues are the larger 2.5" cores, tapered, or stepped baffles that are in some of the louder mufflers being marketed.
Below is an extreme example of a Twin Cam chart showing the effects the exhaust can make on a 100Hp 107" motor.
The stock header with the cat removed and actually even with the cat in it is a pretty good header. When I tested cams with Steve Cole and to this day I am still running the stock header with the cat removed. The gains you'll get from a cam, air cleaner, mufflers, and dyno tune will far exceed any gain you will get from an aftermarket header and you are correct that for the price of an aftermarket header you can get a cam, tuner, and maybe a dyno tune.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Eccool (02-20-2019)
One reason to buy an aftermarket Header is if the coppers decide to defect you.......at least you can return the bike to stock easily to remove defect.....if you decat your original Header, well a decat Header you are stuck with.....
Ps- that’s applicable down here and it’s why I got a Bassani header......dunno how the coppers behave over in the States.
Granted, some states/cities have noise ordinances and I've seen loud bikes get ticketed before, but honestly they offenders were just begging to get pulled. Not sure the M8 would ever be in danger of a ticket like that though. lol
