Rear brake pad change
21017 roadglide special 40k miles. I need to change its rear brake pad and I am stuck. I loosen two bolts and trying to slide brake assembly off the rotor, it wont slide out because it is hitting the wheel. It was never this hard on my 2012 roadking when I change the rear brake pad.
It looks like the rear wheel needs to come off to replace a rear brake pads. What a bad designed
That's weird. I didn't have that problem with my 2017 FLHTK. My rear brake was squealing something terrible after about 1k miles. I removed the caliper no problem. Cleaned it and applied a new layer of brake caliper grease to the back of the pads. I had to wiggle the caliper just right to get it off. If I remember correctly I had to pump the shocks up all the way on my 2012 to get clearance past the wheel. Try turning your shocks up for more clearance.
