Oil change? 107
The following 2 users liked this post by Keithhu:
mjwebb (06-09-2019),
Silentgreyfellow (06-09-2019)
The following 2 users liked this post by Dan89FLSTC:
Dan33klein (06-10-2019),
I'd use Mobil 1 20W50 motorcycle blend, but there doesn't seem to be a reason to not use Syn3. The prices are similar, and my 2018 is still under the factory warranty for another 9 months.
I've never seen any reason not to use Syn3. Both my 2016 and my 2018 used and using Syn3 from break-in. I ride on the hard side, in all weather, with local summer temps typically around 107f and above. Mostly two-up. Lots of highway slow-downs in the LA area, with hot weather slow going. I do up my change interval to 3k miles in the hot weather. My bike uses very little oil, currently pushing to 19k miles.
The following 4 users liked this post by Dynamick:
Campy Roadie (06-10-2019),
porkster (02-01-2021),
Silentgreyfellow (06-10-2019),
slippin_jimmy (01-28-2021)
How much oil you put in has nothing what so ever to do with sumpping. Sumpping s something one does or doe not do. Change your oil and ride. If you are concerned about sumpping is is simple to check.
