Sumping caused by or exasserbated by loose oil jets?
Traveling Tall is posting his performance upgrade build series with Zipper, and one of the guys working on the bike is said something rather interesting.
Time Stamp: 13:47
"Leaking Jets on the back side can be a huge part of why M8 engines can over sump with oil."
I was getting the impression that the sumping issue has more to deal with the case and oil pump design, and pressure build up?
Have you guys heard this before? In all the threads that I have read so far, I do not recall anyone mentioning Jet issues. (I dont have perfect memory so someone could have very well said something about it).
Thoughts?
Excuse the typo in the title, Spellcheck didn't check the title field.
Time Stamp: 13:47
Thoughts?
The following 2 users liked this post by Msquad:
jd05flhtci (11-27-2019),
strych9 (11-27-2019)
Campy Roadie (11-30-2019)
I was still looking at the sportsters.
Thanks for the replies, guys.
The following 2 users liked this post by mjwebb:
Campy Roadie (11-30-2019),
sixguns (11-27-2019)
Time Stamp: 13:47
https://www.youtube.com/watch?v=wnp9pFQANnY
Thoughts?
Time Stamp: 13:47
Thoughts?
T-Man did a video on the piston cooling jets. My bike has never sumped and my screws were a little bit loose. I think it's a good idea to change the gaskets as long as you've got the cylinders removed. I followed his recommendations using Cometic gaskets, allen head screws and sanding the jets flat. It's a really tight space trying to change these out when you have big hands like me. Using the allen head screws makes it easier to torque the screws than using the OEM Torx head screws. My jets were not flat but it didn't take much sanding on my granite counter top to get them that way. Take precautions so you don't drop your screws into the crankcase.
