New S&S 475C Installed ?
Ha guys so just did a big upgrade HD 2020 Oil Pump S&S 475c Cam S&S Tappits & Pushrods, runs like a champ likes higher rpms.
Here's the Question when the bike first starts the front cylinder exhaust valve tics for about a minute & then it's quiet actually better than the sewing machine sound it used to make.
So could it be that ajustable pushrod needs tightened a bit and it's just the Lifter pumping up before it quiets down?
Thanks for your help.
What kind of riding do you do ? I'm still getting used to this one coming from a torque cam I'm riding a soft tail FXDR most of the videos I have seen on the 475 were on CVO or Baggers. seems to want to run hard in the upper rpms not sure about cruising yet
I like to twist on it pretty good, mine comes on strong around 2800 rpms and just keeps on coming after that. Also it's the best sounding cam I've personally heard in an M8.
Sounds silly, but it works. If you love synthetics (like I do) just don't let it worry you.
Yep always synthetic in the motor , wondering if I tightened the exhaust Pushrod just a bit if that would make it go away
Yeah, I run Amsoil, and when I put the BelRay in...it went all quiet! Damn it! I still switched back to Amsoil LOL
Agreed! I miss my cam! Already planning on ditching my SE torque cam next year and going back with the 475c. Unless a new cam comes along for the 114 that sounds as good or better.
I would do the entire procedure for that cylinder, and re-adjust. I would not go more then one extra flat. Perhaps Steve Cole or Jamie from FM will chime in
