Show me your tool combo for p clamp exhaust bolt
This p clamp bolt is a serious engineering failure, at least with my new exhaust. You need a wobbly which barely fits, and took protect the heat shields with painters tape and still it's a cluster ****. Went to the tool store today and forgot about this but. It's 1/2" and with a 3/8 ratchet and wobbly it's kinda doable without ****ing up loosened heat shields, but not really. I used and open ended wrench to do it until it wouldn't line up as there is limited movement due to the rear head pipe. Next try will be a 1/4" wobbly with the 1/4 drive 1/2 socket I got today, but I forgot to get the wobbly.
Anyone have a better solution? I prefer the twin cam vertical fastener attached to the front exhaust bracket. It was far simpler to get to. I also got a crows foot 1/2" I can attach a 3/8 ratchet to. But doesn't look like it's gonna work without a wobbly. Look close you'll see I scratched the heat shield installing it. D' oh!
The following 2 users liked this post by sixguns:
AFSOC_Commando (01-14-2021),
smitty901 (01-12-2021)
My front head pipe sits way higher than that. It is impossible to get a straight shot to the nut. I now, it's a no brainer when it's a straight shot. I'll get the painters tape out and use a 1/2" deep well with an extension so you can see. I don't think a deep well socket will even fit on it...Stay tuned.
The following 2 users liked this post by golfblues:
s-glide76 (01-12-2021)
Received 19,761 Likes
Couple of different ways, use a wobble extension. A set of 3/8 & 1/4 wobble extensions can be had at your Harbor Freight Store. Or go with a flex 3/8 inch drive 1/2 inch six point flex socket. My set is Husky but cannot remember where I got them as they are at least 40 years old. On my Trike it is a pretty straight shot so yours may be different.
The following 2 users liked this post by RANGER73:
Hamps (01-13-2021),
jd05flhtci (01-13-2021)
jd05flhtci (01-13-2021),
JohnA. (01-15-2021)
