drop a 114 into a 107?
Old 11-18-2022, 10:25 PM
Taxgod4u's Avatar
Taxgod4u
Taxgod4u is offline
Received 1,032 Likes on 472 Posts
Default drop a 114 into a 107?
Is an engine swap of 114 into a 107 bike a simple plug and play or are there other issues that need to be addressed? Bike would be a 2020 - 2022 Street Glide Special.
Old 11-18-2022, 10:29 PM
mjwebb's Avatar
mjwebb
mjwebb is online now
Received 8,768 Likes on 4,538 Posts
BCM & ECM come to mind as being mentioned as different
talkingrock (01-18-2023)
Old 11-19-2022, 12:02 AM
VernDiesel's Avatar
VernDiesel
VernDiesel is offline
Blown 2020 107 out of warranty? Found a wrecked 2022 114?
GPHDXLC (11-20-2022)
Old 11-19-2022, 12:15 AM
Taxgod4u's Avatar
Taxgod4u
Taxgod4u is offline
see 107's w/ 30K on them selling cheap (mid to high teens) and need a project. Have cash set aside to buy a 2023 SGS or CVO but enjoy the build as much as the ride.
patzx12 (11-21-2022)
Old 11-19-2022, 05:30 AM
dajogejr's Avatar
dajogejr
dajogejr is offline
I’d buy the 107, get a big bore kit, cam, breather, tuner, etc.
Going from a stock “ish” 107 to 114 is not a lot to gain, you’d be on better footing leaving the 107 and upgrading that.
Still be a build and will be easier to source and install parts rather than swap power plants….
The following 5 users liked this post by dajogejr:
GPHDXLC (11-20-2022), M Oclaf (11-20-2022), mjwebb (11-20-2022), talkingrock (01-18-2023), VernDiesel (11-19-2022)
Old 11-19-2022, 10:11 PM
VernDiesel's Avatar
VernDiesel
"All things in moderation except acceleration, have cash set aside, and enjoy the build as much as the ride" All of these things suggest to me to build a cheaper bike as opposed to buying a new CVO. Plus with the M8 its so much easier and cheaper and more reliable per HP than with previous motors.
Personally I prefer to start with a 107 as it has the shorter 4.375 stroke. Which is already a relatively long stroke. If you are building a two up trailer toating touring motor you want the longer stroke even a 4.625. But if you want to make HP and retain maximum reliability you might prefer the shorter stroke. All things being equal best naturally aspirated HP comes through rpm. A shorter stroke has less piston speed and less piston side loading at the same rpm which leads to better ring seal and piston / cylinder life. True the difference in stroke is not dramatic so perhaps to the rpm and horsepower level you wish to attain its negligible and the additional displacement out weighs that. That's for you to decide just sharing my thoughts. If you are building a 170 HP motor and want it to live the longest while regularly seeing 6500+ rpms perhaps its a fair consideration.
Old 11-20-2022, 08:22 AM
GPHDXLC's Avatar
GPHDXLC
GPHDXLC is offline
Originally Posted by dajogejr
i’d buy the 107, get a big bore kit, cam, breather, tuner, etc.
this 😊
Old 11-20-2022, 10:48 AM
Taxgod4u's Avatar
Taxgod4u
Taxgod4u is offline
Thanks all! I tend to ride one up and between 2,250 and say 3,750 rpm. Will def consider the 107 and a TQ cam & tune. Being over a half century old I save the WFO for the dirt.
The following 2 users liked this post by Taxgod4u:
Old 11-20-2022, 11:54 AM
FLTRI17's Avatar
FLTRI17
FLTRI17 is online now
Using a 107 to 114 big bore kit will increase torque (~10lbs) and provide an acceleration noticeably better than the 107. Overall a nice easy effective and inexpensive change. Add a cam and hold on!
Bob
mjwebb (11-20-2022)
Old 11-20-2022, 12:30 PM
downzero's Avatar
downzero
downzero is offline
Received 1,959 Likes on 1,097 Posts
People who say this often fail to realize that a larger displacement engine makes more power everywhere than a smaller one, all else equal. There is no replacement for displacement.
Quick Reply: drop a 114 into a 107?
