High Speed Shakeing
High Speed Shakeing
With new tires and ride on sealant/balancer the bike rides perfect, could not ask for a better ride. But around 110mph the front end starts shaking, its definitely in the front end and letting off the throttle, slowing in high gear the shake will continue until around 70mph as it fades away. A Honda dealer mounted and added the ride on, I was not present could it be incorrect amount added?
I had removed the weights from the front wheel before getting the tires mounted. It was 11 weights 5gm each or 55gm is 1.94 ounces. I'm grasping at straws but the seems like a lot of weight. Could it be that the sealant can't balance it if it's that far off?
No, the issue is that you're letting off the throttle. Anything over 108 and you have to keep the throttle open and accelerating. I know, because I'm still on the bike accelerating right now.
The weight required to balance wheels changes with every set of tires mounted. If you didn't balance the wheels with the tires that are mounted now, you have no idea how much weight would be required. Ride-On uses a certain amount by the tire size, not by the balance weight required.
I called and they will recheck it on there balance machine.
All i can say is , ummmmmmmmm , are you anywhere near the bonneville salt flats ? Harley baggers will go that fast but that does not mean that you should . I know it is fun for a minute , however , they are not built for that kind of sustained speed anyway . I once pegged the speedo on a honda 70 trail at i believe 55 mph going down a very long hill . They were not built to go that fast either , not a great experience and well before social media videos , but i am sure it would have been a winner with millions of hit's . Be safer and live a while ---------
