2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
What bugs in 1.20.3 update?
Old 02-20-2017, 12:58 PM
Tanker2's Avatar
Tanker2
Tanker2 is offline
Default What bugs in 1.20.3 update?
I updated to 1.20.3 and got along fine. Only bug I have found so far is, when you start the bike with radio in the USB mode, it works fine but the top of the screen where it shows your in USB, constantly flashes between reading and USB. I went to FM and back to USB and then it quits flashing between the two and shows just USB like it should. Anyone else noticed this? . And for me the side tone does works on my intercom. Not as well as on my 2012 Ultra, but does work. I never use the CB, so don't know about it. So what other bugs have you found?
Old 02-20-2017, 02:08 PM
VinceTheArchitect's Avatar
VinceTheArchitect
VinceTheArchitect is offline
I've noticed that, too. I just figured it was indexing my USB stick, as I have a decent amount of music on it.
Old 02-20-2017, 02:41 PM
Tanker2's Avatar
Tanker2
Tanker2 is offline
It never did it on 1.20.1 and I have the same USB stick with same amount of music. Not a big deal, but kind of annoying
Old 02-20-2017, 05:52 PM
Harttoo's Avatar
Harttoo
Harttoo is offline
Mine wouldn't turn on today.Just showed clock.Shut it off and restarted and Display was blank.Drove any way and pushed the button to display temperature and it came on.I managed to get to a music display but, no sound.Shut off waited 10 minutes.It came on and worked correctly.Programmed 1.20.1 when I got home.
Old 02-20-2017, 06:14 PM
Sunnyday91360's Avatar
Sunnyday91360
Sunnyday91360 is offline
Oh yes, Tried multiple downloads, multiple thumb drives (different sizes), multiple resets, files in folders in root dir, files not in folders in root dir, beat it with hammer, still reading usb...reading usb, etc. etc. .. it must be looking for something that just ain't on my bike. Basically fixed one thing and screwed up something else. Does sound better, so will live with until 1.20.4 thru .99, which ever one fixes it.
Old 02-20-2017, 09:04 PM
White Ice's Avatar
White Ice
White Ice is offline
I have found no bugs other than the same one you describe. I'm using an ipod nano (the little 1" square model) with approx 2200 songs on it. Occasionally the top line flashes between READING and USB. Yes, there is CB side tone.
djhrln (03-10-2017)
Old 02-20-2017, 09:26 PM
Terminator1's Avatar
Terminator1
Terminator1 is offline
I've noticed all of the above plus the boot up screen stayed on while riding down the road for a few miles before I noticed the "use caution" screen hadn't appeared. What's cool is that it's the CVO splash screen so I didn't mind looking down at it for a glance. Then the caution screen appeared and the radio was back to normal.
Old 02-21-2017, 09:00 AM
Just Me's Avatar
Just Me
Just Me is offline
I still have the 18.??? and have no need to update any further, so far.
Old 02-21-2017, 01:11 PM
Womack's Avatar
Womack
Womack is offline
I have had zero issues with the latest updated software.
I use a 64 gig USB thumb drive on my 2015 RGS.
Good Luck.
Womack
Old 02-21-2017, 02:15 PM
SN8KBYT's Avatar
SN8KBYT
SN8KBYT is offline
Radio cuts in and out when a trip is set in the NAV.
There is a check box called "Enable NAV Prompts" that you have to uncheck to keep this from happening. Only problem is that it re-checks itself every few trips and you have to go back in and uncheck it. Have done this about 6 times already.
Quick Reply: What bugs in 1.20.3 update?
