LA Choppers Bars
Random takeaways from process:
Gotta remove tank to run brake line to ABS module. 4 Bolts and fuel like quick disconnect. Surprisingly easy.
Lots of hubbub about blending ABS brakes. Found one dude that said you can do it as long as power is not applied to bike. i bled the crap out of mine before hooking battery back up....left and right calipers. No issues.
Routing wires through bars sucks. Period. Found using a LOOOONG flathead screwdriver to kinda poke the wire around the sharp angle in the bar worked pretty good....and lube...LOTS of lube. Solid life advice in general. LOL
Other than the 2 katrillion steps tearing the bike down, it technically wasn't a difficult job. Just time consuming.
Anyway....pics.....
torchmaster (03-21-2018)
Originally Posted by torchmaster
Thanks for the write up, Bike and bars look killer.
The brake and clutch cable were to short to use with those bars? I ask because I put a set of Khrome Werks 2+2 sweepers which are higher and have more pullback on the wifes sg and did not have to extend anything.
Originally Posted by ew25950
For comparison, I installed my Yaffe 10's (15 SGS) and didn't mess with the brake or clutch lines at all.
Looking at post 11 from jlcaptain24, he was going from 18's to 8's and that must be why he did the clutch/Brake work. Maybe he will confirm.
http://baggernation.com/item.php?iid=73
torchmaster (03-23-2018)
These are 8" yaffe's that actually measure little over 9". My hands are behind the faring but they look to maybe block your mirror.
Thanks bro
Did you need to extend the brake or clutch line with these?
