Oil Change Question?
RE: Oil Change Question?
more to do with the mileage IMO, as i changed the first lot at 50 miles, then 500, then 1000 then went amsoil at 2200 People here are going to dissagree, but let it run to 2k on dino first then go syn...
I just pumped up my 88 twin cam to 103. New Crank, flywheels, pistons, heads, barrels and cams. From the first time it started till present it has had nothing but AMSOIL in it. Everything seated just fine. no oil consumption. So I guess the answer to your question is YES...
Bear
03 Ultra Classic
Screaming Eagle 103 and 6 Speed
Bear
03 Ultra Classic
TOMMYBLAZIN
Oil Archive (no new posts)
05-25-2018 10:36 AM
