ANY 1 USING A REUSABLE OIL FILTER
Anyone have expierence with either a PurePower Reusable Oil Filter \\;or a K&\\;P Reusable Oil Filter?Recommendations on which one is better or how well they work?Regards,Tom [/align]
RE: ANY 1 USING A REUSABLE OIL FILTER
my thought is the standard disposible filter does as much filtering as the motor needs. For the cost and added mess of washing out a filter, I don't see it.
ORIGINAL: big cahuna
I used one of these Scotts reuseable oil filters on my 02 sportster. Traded in the sportster on the dyna I have now. It was a very well made product that was easy to remove an clean. Liked the magnet on the internal element as it picked up alot of powder type particles on it at each cleaning. There was really no big mess to clean it. I just rinse the filter out an wiped out the inside container an reassemble. Maybe 5 to 10 minutes to clean it an assemble. But also lowered my oil temp by 10 degree's. The o-ring that seals to motor on housing you did not have to replace. Had mine for 4 years on the bike with never a leak from o-ring. I am thinking of getting one for my dyna now. It is expensive versus just buying filters but that is just up to the individual. Is it better than a regular oil filter could tell you.
http://www.scottsonline.com/products...HarleyDavidson
ORIGINAL: TOMCENTRAL
Anyone have expierence with either a PurePower Reusable Oil Filter \\;\\\\\\;or a K&\\;\\\\\\;P Reusable Oil Filter?Recommendations on which one is better or how well they work?Regards,Tom [/align]
Ron
ORIGINAL: rbabos
Convert the 30 micron to thousands of an inch and ask yourself how you feel about that size of partical traveling around, over and over in the oil. Just not fine enough for modern engines, especially the tc 96 with hydraulic tensioners.
Ron
Anyone have expierence with either a PurePower Reusable Oil Filter \\;\\\\\\;\\\\\\\\\\\\\\;or a K&\\;\\\\\\;\\\\\\\\\\\\\\;P Reusable Oil Filter?Recommendations on which one is better or how well they work?Regards,Tom [/align]
Ron
I am using this filter\\;
http://www.gopurepower.com/store/ite...ItemID=8110-BF
I am running a Heritage with a 116 custom built engine putting out 128 HP and 132 FPT. \\; I wanted every bit of cooling I could get. \\; The filter is kind of a pain to clean, but if they can do it at NASCAR, I guess I can handle it. \\; The only problem is that I have to remove the NOX bottle to change the filter, one of my better installation ideas.
THE HD FILTER ONLY FILTERS 5 MICRONS 80% OF THE TIME &\\;\\\\\\;\\\\\\\\\\\\\\; ZERO ON COLD STARTS BECAUSE IT BYPASSES THE FILTER!THE K&\\;\\\\\\;\\\\\\\\\\\\\\;P FILTERS 35 MICRONS 100% OF THE TIME.Regards,Tom pslus the K&\\;\\\\\\;\\\\\\\\\\\\\\;P flows 7Xs more than the hd spin on &\\;\\\\\\;\\\\\\\\\\\\\\; decreases engine temps.Dan Baisley recommends them,especially for the TWINCAM 96s. \\;\\\\\\;\\\\\\\\\\\\\\;
ORIGINAL: rbabos
Ron
Anyone have expierence with either a PurePower Reusable Oil Filter \\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\;or a K&\\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\;\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\\\\\\\\;P Reusable Oil Filter?Recommendations on which one is better or how well they work?Regards,Tom [/align]
Ron
Ron
