oil funnel
oil funnel
Which oil filter funnel works better for draining/removing filter, the Harley one (with a little hose) or the Ernst orange funnel with a slight angled spout ? Will use with a '04 Road King. Thanks.
I've not had luck with any of the funnels, soda bottles, or the other tricks people have used. Oil always seems to end up on the engine.
I use a PCS4C permanent filter and I remove and clean it with the bike cold on a J&S lift; the oil when cold is drawn back from the billet housing and I can remove the filter and clean it without dropping contaminated oil on the engine or in my case, the front isolator.
I've ordered a DK Custom oil filter relocation kit; waiting on the tracking number, I'll post up images in the Dyna forum when I get it installed. I've found no trick beyond relocating the oil filter is an acceptable answer.
I`m interested in the DK Relo unit also but will let TinCup be the guinea pig. I have had very good luck with the form a funnel.
http://www.formafunnel.com/
I cut the plastic 2 liter soda bottle up and place under the filter. As long as I break the filter loose before and keep the bottle tipped I might lose a couple of table spoons of oil. I also shove some paper towels under the filter before too. Not worth it for me to buy another accessory.
I took a 12 pack of soda, and cut the top off and lined it with aluminum foil. Worked perfect. Tried the soda bottle, but still got oil all over.
Received 1,936 Likes
I cram paper towels everywhere I can under the filter, then use the Harley orange thingy.... not a drop spilled.
I also have/love the big flat HD drain pan, tho it's pretty ridiculously priced.
'15 Limited Low
For ROCKOUT information & purchasing please click the LINKS below...
'15 Limited Low
__________________
NO, they DON'T all do that!
Also on amazon.com...
