Oil Archive (no new posts) An archive of oil related questions and comments.
Twin Cam Oil Pressure Issues
Old 11-07-2010, 11:03 PM
editbrain's Avatar
editbrain
editbrain is offline
wrong thread. Have to many windows open.
Old 12-22-2010, 05:05 PM
defilipps's Avatar
defilipps
defilipps is offline
4th Gear
I am experienceing the same issues with oil pressure light coming on @ idle. I just installed the HD Screamin Eagle oil pump, support plate, new bearings, hydraulice cam chain tensioners and adjustable pushrods. The bike absolutely runs great except for the fact that my light comes on intermittently at idle and my oil pressure is about 50% of what the spec is (using a external, known good oil pressure gauge). I am stumped any ideas?????
Old 12-22-2010, 05:51 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
idle RPM?
low idle = low oil pressure
Old 09-04-2011, 10:37 AM
The Shute's Avatar
The Shute
The Shute is offline
Having same issue, after installing new cam tensioners, new oil pump, new push rods. Started bike up and got the red engine warning light, removed oil filter to check if oil was getting to it. It should have sprayed out but no oil. Went to re-assemble the push rod tappets were full of oil. Any idea what issue could be?
Old 09-26-2011, 06:24 PM
OldRed's Avatar
OldRed
OldRed is offline
5th Gear
Idle speed must be checked in all twin cam engines. Idle should be no lower than 700 or 800 rpm for correct oil pressure at idle. I'm quoting the rms off the top of my head. This seems way too high for us old schoolers but it is correct. I'd start there first. Check your maintenance manual for correct idle. Adjust. Then, oil viscosity. I'm using 20-60 redline here in Arizona....except for the coldest months. Makes a huge difference in engine noise as well. If that doesn't fix it. Then start the shakedown. Mount an oil pressure gauge on the bike to see your pressure as you ride. Continue shakedown as required.
Old 09-26-2011, 06:42 PM
Stiggy's Avatar
Stiggy
Stiggy is online now
Received 5,604 Likes on 3,084 Posts
Mine runs at 1050 rpm...and I've never seen that light at idle.
hawkmaneg (05-09-2018)
Old 07-22-2013, 08:33 PM
e_minor_pentatonic's Avatar
e_minor_pentatonic
e_minor_pentatonic is offline
I have an 03 Dyna Superglide and my engine light was coming on when riding about 60mph. It would go off above and below this. I put an oil pressure gauge on and I was running low pressure. I put in an oil relief spring from http://www.ertproducts.com/ and it brought up my pressures to HD spec. I took it for a ride and the engine light came on more then ever. I took off the oil pressure switch and cleaned it with carb cleaner and no more engine light. I'm glad the switch made me check my pressures as we all know oil is the life of the engine, but it does no good if the engine is not getting the oil it needs.
bigheadted
Engine Mechanical Topics
15
04-07-2016 10:58 AM
HighonHarley
02-08-2015 07:32 AM
Pops98
02-01-2015 05:05 PM
HDF Tech
06-16-2012 06:09 PM
hdfatboy54
Exhaust System Topics
03-01-2008 07:37 PM
Quick Reply: Twin Cam Oil Pressure Issues
