Oil Archive (no new posts) An archive of oil related questions and comments.
Syn3 in the transmission
Old 11-01-2005, 02:41 PM
txHarleyMan's Avatar
txHarleyMan
txHarleyMan is offline
Default Syn3 in the transmission
Is it safe to run Syn3 in the tranny? Just seems to me it is too light for the transmission? I have a 00 FLHTCUI and am thinking about replacing the tranny oil with a Mobil semi syn.
Thank you.
Mike
Old 11-01-2005, 03:46 PM
oldgeezer's Avatar
oldgeezer
oldgeezer is offline
Default RE: Syn3 in the transmission
I would not run Syn3 in the tranny. Use either Mobil 1 or Amsoil 75W-90 or Redline Shockproof Heavy.
Old 11-01-2005, 05:22 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
I would NEVER run syn 3 in the trans. It needs a gear oil like said above.Mobil 1 75/90 or redline shockproof heavy.
Old 11-01-2005, 06:42 PM
solorider's Avatar
solorider
solorider is offline
And as an FYI for others...even Harley isn't recommending Syn 3 in the '06 trannies.
Old 01-07-2006, 05:16 AM
wlbowers's Avatar
wlbowers
wlbowers is offline
Funny! Just had the 1000 mile done on my Low Rider and they put Synthetic everywhere.
Here is the Harley page on Synthetic oil.
http://www.rmh-d.com/parts/syn3_faq.php#a10
Lee
Old 01-14-2006, 12:21 AM
JLOCKHART29's Avatar
JLOCKHART29
JLOCKHART29 is offline
Been running SYN 3 in all 3 holes for the last 24000 miles and no problem but still have reservations about it. I figure if it hasn't done any harm yet I might as well stick w/ it.
Old 01-14-2006, 12:28 AM
brianseay's Avatar
brianseay
brianseay is offline
Same here, Had the 1k done and they put syn3 all the way around. They told me it would be fine. I have thought about making the changeover to Amsoil at the 5k oil change. I ran Amsoil in my Yamaha and had no problems at all.
Old 01-14-2006, 12:35 AM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Without getting into the discussion too deep, gears in the tranny need gear oil because of the shear factor from the gears. Engine oil in the tranny is a mistake and as stated above HD doesn't recommend it in the 06 bikes.
Because you have significant miles on it and it hasn't seen any problems does not make it OK . It could possibly be seen in a different light that if you were to use gear oil in the trans that you would possibly get high mileage out of the trans whereas with the syn three. you may even make some decent mileage but not as much as you would with a gear oil. Why wouldn't you use straight 10 weight in the engine applying this theory???
Old 01-16-2006, 11:31 AM
vagunter's Avatar
vagunter
vagunter is offline
Just My 2 cents. I did the 1k service on my sportster and switched out the primary oil with syn and really dont like the way it feels. sounds a bit nosier too so Ill be switching the oil back to the formula plus.
Chris
Old 01-16-2006, 03:49 PM
tripl8's Avatar
tripl8
tripl8 is offline
Redline Shockproof for the V-Twin tranny....................Sync3 is poisen.
Quick Reply: Syn3 in the transmission
