Oil filter mount adapter specs.
Just changed my oil in my 2008 Dyna Fat Bob. The filter was put on too tight or cross threaded by the last guy. When I unscrewed the filter, the male-male adapter that goes into the mount came out with it. (Pic below). Long story short, I couldn't get the adapter out without destroying the filter and I wasn't confident the adapter could be reused. I put the old filter back on and it threaded in fine with no leaks. Ordered a new adapter.
I have looked through the service manual and done quite a bit of searching on here but I cannot find the proper procedure (thread treatment, torque specs) for this adapter. I am sure it is out there but it has eluded me. Can anyone help?
Here is the adapter I ordered. Harley was 7-10 business days as usual.
Oil Filter Adapter
Oil Filter Adapter
What's hard about getting that out??? Clamp the filter in a vise and squash it good. Then with the proper size socket, a combination wrench or an adjustable wrench unscrew the adaptor. Clean out the threads in the filter housing and adaptor, add some red LocTite to the correct end and tighten it in to the housing. No need to torque it. Just run it in snug then give it final tug and it's good. Let it sit a bit before you install a new filter, add oil and start. No magic here.
The following 2 users liked this post by Hey Man:
MotoJockey (04-05-2023),
Vec (04-05-2023)
I appreciate the advice though. I just want to be careful with integral pieces. If I crack something now I will miss my upcoming road trip.
Lightyear68
Oil Archive (no new posts)
17
01-23-2015 12:07 PM
