Does Punching Oil Filter Damage the Mount Threads?
I've been reading the dozens of ways that folks remove their oil filters with the least mess possible.
The combination that makes the most sense to me is to (1) use a flexible material that rests under the filter against the base to channel oil into a container, and (2) to use an awl to punch a vent hole at 12 o'clock and drain hole at 6 o'clock into the base of the filter.
I like the idea of removing the filter with minimal oil draining from the seal-end.
Mechanically speaking, it seems to me that the forces resulting from driving the punch into the filter base could be transmitted forward and damage the threads on the mount.
Many on our forum have done this successfully, so I'm thinking that the force to drive a sharp awl into the filter may not be enough to damage the threads...but wanted some informed opinions.
And is it true that the filter has two layers through which we need to puncture to get max oil drainage?
So I turn to my trusted forum friends for (1) the knowledgeable insight and experience from the serious among us, and (2) the inescapable condescension and sarcasm from the ball-busters among us.
...I like the idea of removing the filter with minimal oil draining from the seal-end.....
I don't think you'll get any disagreement with that notion.
Originally Posted by Lightyear68
...Mechanically speaking, it seems to me that the forces resulting from driving the punch into the filter base could be transmitted forward and damage the threads on the mount....
The threads on both the bike and filter seem pretty strong...wouldn't think that would be an issue. But getting up under the bike (unless you have it on an open-bottom lift) and finding room to work might be a problem.
I guess the downside might be coming across a real stubborn filter and ending up crushing it upon removal (the punched hole might cause a weak area and crush or fold). I've seen that done a few times on cars but not a bike. It really becomes a mess after that.
My last couple of HD's were touring models and I've changed the oil on those many times. Cutting a large plastic Coke bottle in half length ways and slipping it under the filter prior to removal seems to work best for me. I also tuck in under the filter a couple paper towels to catch the few drips.
"Mechanically speaking, it seems to me that the forces resulting from driving the punch into the filter base could be transmitted forward and damage the threads on the mount" ... You're not hitting it with a sledgehammer and a 2x4 ... a sharp long pinch or drift will definitely put a hole in the filter with little to no stress on any parts ...
The sheet metal can will give way long before it could impart enough force to damage the threads.
Originally Posted by grbrown
I've been whacking the oil filters off my Evo for 25 years using a screw-driver and hammer, without any problems. Now what is your query?!
I`ve always hated that method, ever since I came across a filter that was so tight that I destroyed the sheet metal can trying to remove it (I was about 15 at the time, so that would be about 45 years ago ).
I`ve been using a steel band type oil filter wrench for 26 years, and I always tighten the filter (wix 5125) a little past hand tight using the wrench, never had one stick. Oil filters stick because of a lack of lubrication on the gasket.
The best lube to use on the gasket is silicone grease (aka dielectric grease).
Why not just indent the filter with a punch then drill the two holes if you want to lessen the mess and drain the filter?
I thought about drilling a vent and drain hole but then read a post that cautioned against introducing metal shavings inside the oil filter that could end up inside the engine. It sounded like a good reason to stay away from drilling...but damned if I know whether it's even possible for metal shavings to get inside from this method.
Maybe a more experienced person will weigh in on this.
It sounds like a question on a mechanics exam in tech school.
You are WAY OVER THINKING this ... I'm a retired ASE Master Tech and believe me you WILL NOT HURT anything following the procedure I mentioned earlier.
