I tried the "total" oil change method...
And it was pretty simple!
All's you need to purchase in a cheap$9 AC/ fuel line remover kit at Autozone, and a few feet of vinyl 3/8 tubing.
I can also comment that I now know, you DEFINATELY leave a good amount of skank oil in the system with the normal drain/fill type oil change.. After I disconnected the oil return line, I ran the bike to purge out the skanked oil, and it's was dark brown, it took about a good 45 seconds to purge until I observed a clean, golden color of oil exiting the line. At least I now know, when I change my oil, ALL my oil is starting out clean....
RE: I tried the "total" oil change method...
No disrespect, but I've been changing my own oil in scooters, cycles, and cars for almost 50 years by the old fashioned method and have never seen the slightest indication that a small amount of "skank" oil hurts anything.
ORIGINAL: Uncle Scrooge
But thanks for the 50 years of experience. Just for the record, I've also wrenched on everything with 2 and 4wheels for the past 28 years.....
I do however change my own fluids in my cars, my bike etc. Back when I rode a,( sorry for the bad word coming up ) Honda 750, and my brother had one also, we'd change our oils together.
Well we also wanted the old "Skank" oil out, but no oil return line,, so we'd leave the run switch to off...(the motor would still crank) and crank the motor a few cycles and watch the "Skank" oil pump out. Then, clean up fill with fresh 20-50 and be done with it.
So rather than removing the return line on the Harley, why not just disconnect the plug wires,,give her a few cranks..and.....watch the "skank" pump out? Any reason this wouldn't work?
I'm curious to see what you guys that turn wrenches for a living have to say..
Ride safe, and often
ORIGINAL: Soft06
But I also believe that it's your bike, and if it gives you peace of mind then do it.
Just my .02...
20+ years here...but that is besides the point. I dont feel that running a motor with no oil in the sump a good idea under any circumstance no matter what kind of WONDER OIL you may use.Skanky oil? WTF? That would/should only happen if the oil wasnt getting circulated through the system and there was a collection point for it to gather to get skanky.
Dont get me wrong....I aint bashing, just kind of wondering......"why?"
But, if it feels good, do it.
seeing that i have been a mechanic for 150+ years, ive never ever heard of oil being "skank".. is that professional term. "skank" used to refer to less than desireable female, not oil. use a good quality oil, a good filter, change it between 2500 and 5000. and u should never have an oil related problem
