O-ring Part Numbers
O-ring Part Numbers
What are the part numbers for the o-rings for the oil tank drain plug, primary drain plug, and transmission drain plug for a '04 Softail? The H-D site does not list these parts. Where can I get these part numbers online. Sure would be helpful if the parts book was online somewhere. Thanks.
RE: O-ring Part Numbers
The part numbers for my Heritage Softail are: O-rings....11324 , 11105 and the Gasket # 60567-90C for Primary. Hope this helps. Not sure which part # is for drain and/or Tranny but they are the numbers above.
buy the o-rings one time from the dealer, then go to home depot and buy a small box of them and write the number size oring in your book. it will save you money and time running to the dealer
Andy
[sm=grinangel.gif]
Andy
[sm=grinangel.gif]
ORIGINAL: a21m
Andy
[sm=grinangel.gif]
Andy
[sm=grinangel.gif]
Hopes this helps and as soon as I have a o-ring cross-reference chart read, I'll put it on the forum
P/N 11105 -- fits transmission and oil tank drain plugs
P/N 11324 -- fits primary drain plug
P/N 11132 -- fits transmission dipstick
These part numbers for for a '04 Softail but may be the same for other H-D models (not sure).
When I get to Home Depot and cross reference the sizes to the o-rings I have, I'll add that table here.
I tried this route, and, for example, H-D 11324, could be either a #6 or #7. Although the size differences are small, I can't be confident of the right match.
fireman9513
06-27-2015 03:31 PM
