stripped drain plug
Old May 23, 2013 | 08:28 AM
hardheaded's Avatar
hardheaded
Default stripped drain plug
my brothers streetglide primary drain plug stripped coming out last night, first time the oil been change too. anyway, does anyone know what size timesert or heli coil this takes to fix? thanks.
Old May 23, 2013 | 09:06 AM
beary's Avatar
beary
I just replaced my pan, seems like it wasn't much over a $100. I've had so so luck with heli coils in the past on cars, so I didn't want toeven hassle with it this time.
What made me mad about it was that I used a torque wrench when I put the plug back on. The Harley mechanic told me that they had stripped several plugs at Harleys recommended torque setting, so now they just get them snug.
Beary
Old May 23, 2013 | 09:08 AM
Scrmnvtwins's Avatar
Scrmnvtwins
Agree with the pan replacement, easy to do and you won't risk leaving metal shavings in your oil reservoir
Old May 23, 2013 | 09:18 AM
hardheaded's Avatar
hardheaded
this is the primary chain case drain plug i am talking about, not the oil pan drain plug. i can't believe these drain plugs would strip this easy. this is the first time this plug has been taken out from factory new.
Old May 23, 2013 | 09:24 AM
soft 02's Avatar
soft 02
Id Heli coil it. Then you know you have steel threads instead of aluminum threads in there. Im sure timeserts are good but I have a whole box of Helicoils so till those are gone thats what I have.
Old May 23, 2013 | 09:30 AM
hardheaded's Avatar
hardheaded
i was looking to find out what size it is as the bike is at my brothers house and would like to have everything i need before heading out here.
Old May 23, 2013 | 09:36 AM
Lowcountry Joe's Avatar
Lowcountry Joe
How did it strip unscrewing it? Or did it strip after you attempted to reinstall the plug?
Old May 23, 2013 | 09:54 AM
hardheaded's Avatar
hardheaded
first time the plug has been out. he said the threads came out when he pulled the plug, said it was hard coming out the whole time he was unscrewing it. i'm guessing it was installed incorrectly from the factory. i have not seen it yet,but was thinking a time sert or helicoil would be the fix. i also was thinking about a self tapping oversize drain plug from the auto parts store.
Old May 23, 2013 | 09:58 AM
davessworks's Avatar
davessworks
Should be a warrantee issue then. Of course good luck with that.
Old May 23, 2013 | 10:05 AM
hardheaded's Avatar
hardheaded
that's what i was thinking also, but their going to say he stripped it, so not even going down that road, gonna fix it ourselves and be done with it. just kinda sucks that it happened right from the factory and he's pretty pissed about it. where's the quality control, is anybody paying attention when they are putting these things together? when i bought my new bike there was all kinds of lose stuff on it, but as so as i buy anything i come home and go over it and make sure everythings tight and right.
