Oil Archive (no new posts) An archive of oil related questions and comments.
View Poll Results: A poll
HD primary oil #99887-84 (old style)
12.18%
Syn 3
14.02%
Amsoil
21.84%
Bel ray
2.51%
Rev tech
1.01%
Dyna cycle
0.22%
Redline
12.07%
Mobil 1
21.47%
Doesn't matter
3.06%
other
11.63%
Voters: 5064. You may not vote on this poll
What Primary Oil is your Choice
Old Apr 6, 2006 | 11:52 PM
OldFenderGuy's Avatar
OldFenderGuy
Default RE: What Primary Oil is your Choice
What do you guys think of using Rotella T 15W-40 non-synthetic in the primary?
Friend of mine gave me a case of Rotella, and I'd hate to see it go to waste.
BTW, I run Mobil V-Twin 20W-50 in the crank and Mobil 75W-90 in the tranny.
Old Apr 8, 2006 | 12:09 PM
a21m's Avatar
a21m
I just switched to shell rotella t 15w40 in the crankcase and primary. no problems that i can tell. everything seems to work fine. i put belray in the trans, but will probably switch to a 75w90 next fluid change.
Old May 19, 2006 | 12:07 PM
Spectrexx's Avatar
Spectrexx
I use whatever is on sale at Walmart or Autozone. 10W-40 works fine for me in temps of 10 deg. to 90 deg. F.
Old Jun 5, 2006 | 09:22 PM
1flhtk4me's Avatar
1flhtk4me
Where do you buy the M1 V-twin oil at?
I think I would use a 4-stroke motorcycle oil that can be used with a clutch in the primary.I have some Motul 20-50,think Ill give that a try.
Old Jun 6, 2006 | 01:16 AM
goodbirds's Avatar
goodbirds
Switched from Syn3 to HD Formula+ in the transmission and primary chain case. First impression is that the tranny shifts smoother/easier. This on recommendation from Zion's ace tech with 28 years experience. The occasion of the oil change was a leak around the shifter shaft and replacing all seals while we were in there. Is it possible the systhetic damaged the seals? Just wondering. The Ultra has 40,000 on it, always maintained by HD.[:@]
Old Jun 26, 2006 | 11:31 PM
Steve On 3's Avatar
Steve On 3
While we're talking oil, I'm having a wrist pin put in my rear cylinder. My mechanic swears it's because the previous owner and therefore on the PO's recommendation, I ran Castrol 20w50 . He says regular oil is not made to put up with the heat especially here in the south. The previous owner had a crate engine put in 20k ago because it developed a wrist pin problem and the dealer forgot to put the keeper in when he rebuilt the top ends. Two engines, two wrist pins. Now understand the previous owner changes religously at 2500 miles, uses Fram filters and never fails to keep up with maintennance. His other bike 97 RK has 170k on it and still running strong.
Did the auto oil cause the wrist pin problems? I dunno, but I know when I get it back, if there ain't synthetic in the crankcase, there soon will be. Probably Mobil1 V Twin and Mobil 1 75-90 in the tranny. Not sure what in the primary, maybe HD formula +
Ride safe
Bubba
Old Jul 3, 2006 | 01:17 PM
skulboy's Avatar
skulboy
3rd Gear
i've been using mobil 1 atf, no clutch drag or slip, haven't had to adjust the clutch outta necessaty, just regular intervals. also noticed less shavings on the magnet!
Old Aug 10, 2006 | 10:14 PM
Honus's Avatar
Honus
Chevron Delo, Shell Rotella and Mobil Delvac 15W-40s wook great in the primary.
Old Sep 11, 2006 | 11:41 PM
glide's Avatar
glide
I use the formula + but I also have the older primary oil which was discontinued .
Old Sep 28, 2006 | 07:37 PM
FLSTC's Avatar
FLSTC
AMSOIL 20W50, no problems yet
