Was riding over some really rocky terrain yesterday and got my first fault alert. Shut off the bike, restarted, alert went away. Kept going over the same rocky road and got another fault.
When I got home and looked up the code it was:
C182314 - Rear damping control circuit shorted to ground/open
Anyone else ever throw this same code? As stated, it happened on really rocky terrain and I was probably going a bit faster than I should've been. I was standing on the pegs and could feel the rear wheel just hammering up and down. Once I got onto smoother roads it went away.
Got my 1k service coming up, will ask the dealer about it, just curious if anyone else has beat up their bike enough to get the same code.
With that message, I'd be investigating the wiring harness connections. Not just unplugging and replugging the connector, but de-pinning them and inspecting the crimp and possibly recrimping and repinning.
I wouldn't. I would just let the dealer sort it out. But if it's an "H" code, I would just clear it and ride. Lots of spurious brain fart type stuff on bike that have this level of tech. if I was HD, I probably wouldn't have let the average Joe have so much access to fault codes.
Rode yesterday including 20 something miles of rocky forest roads. No codes, bike performed flawlessly. I'll mention it to the dealer but not going to worry about it unless it pops up again.
We've always had access to the fault codes since they introduced the CAN bus bikes, this is not new. Same as you having OBDII connectors in your vehicle. We need access to codes to be able to repair our out of warranty vehicles.
But I was speaking as if I were your Harley tech when I said that "I would" start depinning and validating the connector based on those codes.
Gotcha. I know we've always had access to codes and the ability to clear them, but it's always involved arcane button presses prior to the big LED screens - and it's so easy to see them on the Pan. So people see spurious codes at times and think the bike is knackered when it really isn't.
And if you were my Harley tech, then depinning and validating connectors is exactly what I would want you to do. I just wouldn't do it myself on a bike that is in warranty.
Mine does this, at first they said the battery was not big enough, they put a new battery in it, but it is still doing it, On mine the adaptive ride height will also malfunction, either get stuck in high or low. I just took it back in again.
If its under warranty HD needs to have these bikes brought in and checked by technicians, how else are they going to improve quality if no one brings them in when problems arise. When things are brought in, concerns are noted it leads them to see trends and they are able to investigate concerns.
25 plus years in auto/motorcycle dealer service departments as technician, management and now as a teacher, I can say one thing and that is warning lights do not come on for no reason, just clearing the codes does not make the problem go away.
I occasionally get the ride height stuck on high. Also fault or engine light. Everything clears after an OFF/ON sequence.
