1948 panhead smoking
Hi There I have a 1948 Pan it just started Smoking more on start up. The bike OK when Riding no smoke, but when you stop and let it tick over then rev it up you will get white smoke agen. I have done a Compression test it 115psi on both and plugs are black. I have also messed around with the mixture and that has improved the smoke issue alot but it still there. Basically what I need to know is safe to ride a bike that burn oil And is gonna cause damage or just smoke. One more thing Does it make sense Pulling the top end apart or should I just live with bit smoke it is 72years old
The following 3 users liked this post by mxdeanmay:
