Painting tank question
Not sure if this project was completed, or even attempted, or not, but I did a garage paint job on my '09 Crossbones which had pinstripes and emblems. Here are a few pics I took in progress.
I should point out that this was a WWII bomber nose art paint job I did using rattle can (Rustoleum, hammered finish) spray paint in combination with water slide model graphics and finished with professional automotive clear coat. Anyway, there was no bleed through whatsoever. Anyway, just my input.
Great job.
Do you have a lot of experience painting and air brushing, where you felt the confidence to do it with a rattle can?
Or was it good old fashion ***** and ingenuity?
Which ever it was you are extremely talented
Thanks. I got a lot of people thinking I was crazy yanking new tins of a fresh from the showroom bike, sanding the tank and painting it with spray paint from Home Depot. But I had a vision of it in my brain pan and figured I should go big or go home. I sold both new fenders to buy a used Heritage front, and Fatboy rear fenders on eBay to paint and put on. I was happy with it.
That is amazing that you did that from a rattle can.
Great job.
Great job.
That bike looks factory fresh.
Nice prep work with the kraft paper on the table and the jigs built to hold your parts.
You are a bad ***.
Great job and thanks for sharing
Nice work
I want to do the paint on my bike using rattle cans to house of colorhs has. candy and pearl I was just wonder how many cans it took to paint yours and I was going to get a graphic kit for the tank and fenders then clear over it got 97 Softail there anyway you could let me know how many cans it took you including primer and did you do the clear with rattle can or a gun any help / advice would be appreciated
I then applied my faux airplane "sheet metal panels & seams" using a Sharpie (dragging a rag across while fresh/wet to create the faux oil seepage and wind spray), then applied the waterslide model graphics (faux rivets, pin-up girl, "bomber name".
I then paid to have the tins professionally clear coated by a local auto body shop.
I'm sure 2 cans of spray paint would have sufficed, but I wanted to be sure. Contrast that to the Arlen Ness ABS rear fender extender I painted outside and hanging from a tree branch on Sunday , which took less than one (1) rattle can of Rustoleum semi-gloss black spray paint and less than one (1) rattle can of Rustoleum Dead Flat spray on Clear Coat, which resulted in a match to my black denim paint.
To cover the bases, I'd recommend buying two (2) cans of rattle spray paint per piece of tin (tank, fender, etc) and you'll be good. Be mindful IF the cans have paint batch numbers, so all cans match up (they don't usually have batch numbers, but sometimes do). Keep your sales receipt from Home Depot or wherever and you can return whatever cans you don't crack open.
Aside from the common sense of not painting when there's too much of a breeze (it'll blow debris that'll get stuck on the wet paint surface), I'm sure it goes without saying, but there are 3 important cardinal rules for this type of project using rattle can spray paint.
1) Err on the side of spraying too lightly versus too heavily. Stay at the maximum distance recommended and move in from there if needed. Drips from too heavy a coat will 'eff up the whole process.
2) Keep the rattle can moving back and forth constantly while spraying and move past each side of the item being painted, with each pass. If you don't, the area of the item will get twice as much paint as you want it too when you stop moving from one direction and start to return in the opposite direction. Duh, I know.
3) Shake the rattle can often and every few minutes turn the can upside down and spray a couple of seconds to clear the nozzle, while also wiping the nozzle tip with a rag. If you don't, the can will "spit" small paint droplets instead of the fine mist you want/need.
Good luck!
WEATHERED59 (05-03-2017)
