Dyna with first gear problems
Hey guys,
So I have a 2000 Dyna, engine is all rebuilt about 100hp/100tq. I've had an issue where when I go to start in first sometimes my transmission "hops" around. It basically feels like it's popping out of gear and then right back in on its own. It's just enough to kinda jerk me around and then everything is fine. It only does it in first gear and always seems to be 2200-2400 rpm. Doesn't do it every time but maybe half the time? Whether I am accelerating hard or not has no affect on it.
I'm super deliberate when I shift to make sure the problem isn't me not getting things engaged correctly. It just seems like it goes in and out of gear on it's own really quick and just kinda jerks me around a bit.
Bike has about 75k on the clock, trans had been rebuilt around 65k by a place called Jonsies Custom cycles in Central PA. (I don't recommend them).
Is something internal messed up or is there an adjustment or something that needs made?
Thanks, Ken
Thanks, Ken
Thanks, Ken
Thanks, Ken
Tranny problems
Can you clear things up, so we can better understand what is going on? Are you saying that you are attempting to start your bike from cold, after engaging first gear? If so, then start your bike in neutral, which is the normal thing to do, and also gives your starter motor an easier time!
Compensator
So if my compensator is shot it would only effect 1st gear? ... I'm ashamed to admit but I've actually had this problem for awhile but have been ignoring it. Cotton worse though
Before my trans was rebuilt it was basically doing the same thing but in 3rd gear and now the problem is only in 1st gear
Also if I need a new compensator where is the best place to get one? SE one a good value?
So I ended up replacing my clutch and running ATF in my primary. Never run or shifted better.
Neb (06-10-2016)
Thenewguy27
09-09-2018 07:59 AM
Antmf
06-07-2013 09:21 PM
