Need more torque
Need more torque
I'm trying to attain more throttle response from my 2014 ultra limited. I know it's not a sports bike, but I'd just like a lil passing power when needed. I was thinking of dropping my front gear from the stock 33 sprocket to a 32-31 maybe. How will this effect my bike? Should I or shouldn't I do this?
I changed my stock 32T front pulley to a 30T and loved it. I even changed my rear from a 66T to a 68T to even make it better.
Don't just do a 1T change. That will only lower your gearing by 3%, go ahead and change the front by 2T to get a 6% change - will make the effort pay off.
If you want to read my install Thread:
https://www.hdforums.com/forum/dyna-...y-install.html
Big thanks
Thanks man and sorry it took so long to reply I rarely get free time anymore, & I'm still feeling this site out. Thanks for the build too. Another question my new friend, what if any difference in performance is there between a one piece 2-1 exhaust & a 2-1 exhaust with separate head pipes and slip on's.
I cant speak for touring bikes too much but some 2 into 1s will work better than others for a particular build. For dynas the best 2 into 1s tend to be the ones with stepped headers and longer baffle/muffler sections - 2 piece or 1 piece is not a performance consideration.
I think you will find that all 2-into-1 exhaust systems come in several pieces, it isn't practical to make and ship them in a single assembly. As Pilot suggests, a change of only one tooth isn't worth it. You have to remove the entire primary to make such a change, so much better to be bold and make a significant change. I think I'm right in saying that the change to 30/68 can be done with the same drive belt, which saves on the cost of a new belt.
