2003 Dyna Low Rider Clutch adjustment nut seized up?
So I am not sure if I am in the exact right place as I just joined HD-Forums. But I will give it a shot. So I have a 2003 Dyna Low Rider with about 34k miles and the clutch cable broke at the lever just straight snapped. It was just its time I guess. So I went and got myself a new clutch cable and installed it after looking at the old Clymer. No problem easy peasy.. But then to my dismay when I went to adjust the clutch I ran into a little issue. So I took off the Primary cover and the nut that you loosen to back out the adjustment rod is straight SEIZED-UP! I almost stripped the Allen slot and the nut got a little dinged up. So I took a off the snap ring and took out the whole thing the clutch adjustment bolt and release plate. But I left the rod in. What should I do? Buy a new one? Any idea what that costs? Or maybe stick it in the vice. I dont know how sensitive this thing is and dont want to go gommin on it and destroy something that might cost a small fortune. I hate to go to the Harley Dealer as I they will tell me to undoubtedly buy a whole transmission. There closed any how until tomorrow just wanted to see if anyone had any ideas for tonight? IF I get it off and put ti all back together sense I took it apart to I have to do more than just adjust it now?
Yeah I used and 11/16th offset and couldn't get it while it was on. And then took the clutch release plate off with the bolt and nut on and stuck it in a vice and it is still seized up. I fi buy a new plate bolt and nut sense I took it off do I have to adjust anything else. I didn't take the rod out very far when I took off the plate left all that alone. My main concern is if i replace all that stuff can i just throw it back together?
I was just wondering off of I-25 and Arapahoe. There is a dude that works there that I have talked to and he had a bike like yours. Thanks for answering my questions. I just didnt know if sense I took that off it messed with anything in the tranny or on the other side of the bike where i replaced that cable I didnt want to go to the dealership blind cause they would try to tell me who knows you know?
Ok so I replaced the clutch adjuster plate and bolt. And did everything I was supposed to. My new question is this. I am sure that that bike had the original clutch cable on it. SO the new one seems to be like really sensitive unless i put more slack in the line than 16th of an inch I mean i barely have to pull it in at all to shift. Is that how its supposed to be? Can i adjust anything to make this not so tight?
