Bike will not move in gear on the ground!
Road bike the other day. Large noise coming from aft primary cover area. Pulled over and shut off. Restarted bike and put into gear. Bike would not move. Noise sounds like something spinning. Got the bike home and jacked up. Pulled primary cover off and nothing looks broke. Oil looked fresh. Some slack in chain. But nothing big. Put bike into gear and rotated back tire. Belt turns with gear but nothing inside primary turns. Normal? Fired bike up. Put into gear. Everything spins inside primary with no noise. Pulled clutch lever in. Tire still turns. Noise is not showing up with tire off ground. Clutch, tranny? I am going to try to repair this myself so any guesses or suggestions would be great and where to start. Since nothing looks broke I am not sure what to tear apart first. Thanks for your help!
_____________________________
Remember - HD means "Hundred Dollars" everytime.
RE: Bike will not move in gear on the ground!
I agree. Tore it apart. Its the freaking tranny. What the hell. Last thing I thought would blow up on the bike. Seriously, does this happen a lot on HD's. It only has 18,500 miles on it. Although it's a 94 FXSTC. Now I really know why I came up with my signature.
And this case a freaking lot more.
By the way, I found this out by firing bike up without primary cover on. Clutch is engaging with lever movements. Sound is in the tranny. I guess I am not speaking English here but would it be possible that something else besidesa new tranny being installed could be wrong. Anything minor I could look at before I pull trans. I am pulling primary apart tomorrow to get to the tranny shaft. I guess what I am asking here is there anything in tranny that could break, come loose, etc without taking tranny all the way out? Thanks for replies.
How do you know for sure it is the transmission? The clutch could be loose on the splines or spun on the input shaft. Have you drained the trans to see if there is any metal or pulled the cover off the top of the trans to see if there is any damage? Pull the primary chain off and see if you can spin the rear tire and shift gears through all 5 gears, if the trans stays locked up then I would say something is wrong in the trans, if it shifts fine then I don't think anything is wrong with the trans. Good Luck.
Front tranny sprocket it is. Big *** nut backed off and sprocket spun leaving zero splines. Very poor design. Found out they made a upgrade the next yr (95) to a thicker spline which is a kit. Cost of repair including sprocket kit, gaskets, seals,oil and I went ahead and replaced starter clutch was 171.00. Not bad considering at 55 mph went spun it sounded like my tranny came apart! Thanks everyone for their help. I am pretty sure I saved myself some money doing it myself except for the beer my buddies drank of mine watching me do it!
Later
Later
