Primary case 1990 flstc
I ordered a delkron inner primary case from j&p, the fitment is perfect to the outer primary cover & to the crank case & transmission bolt pattern, but the bearing & seal for the transmission output shaft & the race & seal for the starter output shaft are way too small, I've never had to order the above mentioned parts before, I obviously didn't get something right, I didn't see anywhere to input the shaft and bearing sizes on the order form, how many different sizes are, I have a feeling that this is gona be difficult to get the correct parts
Well i'm not sure on the different sizes but first thing you need to do is call j&p and tell them your situation.If for nothing else ,to return that inner primary.talk to a supervisor to get your answers.If that dose not work call delkron and see what they say.good luck , sometimes getting the right part is a "p.i.t.a."
