Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Transmission Sprocket Locking Tool - Easier
Old 09-13-2017, 07:32 AM
Mike_Spain's Avatar
Mike_Spain
Mike_Spain is offline
Stage I
Default Transmission Sprocket Locking Tool - Easier
Yep, that skinny nut that holds the front drive sprocket. How to lock the sprocket against 200ftlbs:
A picture tells all. The longer story...
Found '95jy's' post from a few years ago (https://www.hdforums.com/forum/prima...l#&gid=1&pid=1), which is a bit of belt attached to a wooden wedge.
Nice idea, I can make that, I work on 50cc&125cc twist-and-go scooters, I've got loads of old variomatic drive belts lying around, and lumps of wood.
So I found a belt. And I looked at the sprocket. And I thought, there's a handy looking big stud.
2 minutes later, I was swinging on the end of the breaker bar like a chimp.
Hope this helps someone else. Your local twist-and-go 'ped repairer will have a bucketful of old belts, they get swapped out at 8-10,000 miles.
Mike
bentparts (02-10-2018)
95yj
12-02-2020 07:20 AM
Pothole914
EVO
15
02-18-2018 04:33 PM
rkoivisto
13
12-07-2016 03:40 PM
Fossil
09-08-2009 07:20 PM
Stel67
08-24-2006 02:59 PM
Quick Reply: Transmission Sprocket Locking Tool - Easier
