Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Trans Sprocket Locking Tool
Old 01-07-2018, 01:30 PM
bustert's Avatar
bustert
bustert is offline
well this is a jist of it. there was a frame member at the bottom of the aluminum bars each side, use your tom terrific hat and i am sure you can get-r-done.
Old 01-07-2018, 05:53 PM
Jamn's Avatar
Jamn
Jamn is offline
Thanks, I'll see what I can come up with.
Old 01-07-2018, 06:24 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,875 Likes on 3,342 Posts
What I have done in the past is while sitting on the bike I would apply the rear brake (very firmly) and with my socket and torque wrench tighten it to spec. It's not easy but I have done it. You can always have someone else applying the brake... Much easier.. 110 ft lbs...
Old 01-08-2018, 02:05 AM
TomCop's Avatar
TomCop
TomCop is offline
Originally Posted by Jamn
I understand, but I'm tightening the Trans Sprocket nut behind the clutch assembly. So clutch and compensator are removed.
So you a need pulley locking tool.
Old 01-08-2018, 09:48 AM
Jamn's Avatar
Jamn
Jamn is offline
Yes. But looking for another alternative if possible.
Old 01-09-2018, 03:17 PM
djl's Avatar
djl
djl is offline
Received 2,046 Likes on 1,509 Posts
I have the tool in the pic TomCop posted which I am willing to rent; however, I would require a postal MO in the full amount of the cost of the tool in case I never see it again, plus the outbound and inbound shipping cost; I would return the MO when I received the tool back in good condition. By the time I get the MO and you get the tool, say 7-10 days, you could have removed the trans top cover, shift drum and put the trans in two gears, doesn't matter which two, which locks the trans allowing you to install and torque the trans pulley several times. If the bike was a softail, not so easy but on a touring model, a piece of cake; your call.
And no, it's not risky.
Old 01-09-2018, 06:58 PM
Jamn's Avatar
Jamn
Jamn is offline
Thank you very much. I popped the top tonight. Trans gets locked up tomorrow.
Old 01-09-2018, 07:41 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 5,281 Likes on 3,642 Posts
AFAIK this only works for 5 speeds. On a 5 speed, you pop the top and remove the shift drum.. On a 6 speed, you can't do that..
Old 01-10-2018, 10:09 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
I prefer an impact.
Old 01-10-2018, 10:46 AM
djl's Avatar
djl
djl is offline
Never tried locking a six speed as I described in my previous; have used this approach on five speeds several times. However, if what Max posted in #18 is correct, and I have no reason to doubt, the offer to "rent" the OP the tool still stands. So, Jamn, PM me if you need the tool.
Quick Reply: Trans Sprocket Locking Tool
