Redline is the answer to the Whine
I wanted to share the results to some issues I was having with my 07 RoadKing. I took the bike to the dealer to have the 1000 mile transfusion and some typical adjustments, and when dropping it off asked service about Redline. They indicated that they have never put Redline in an 07, that the oils suggested by HD would heal the problem. I pickup the bike up that night and quickly noticed the whine was gone. After riding for a while I noticed the whine reappearing. That suggested a possibleissue with viscocity and oil breakdown which may be the culpret to the issue.
On the way home I placed an order for Redline Shockproof Heavy, pickup up the order several days later, installed and in an instant knew the problem was gone. Shifting was smoother, first gear whine was less and when I sped up enough to get to fifth I had to count the gearsbecause I had no idea I was in fifth. That whine was also gone. After several days and several hundred miles, I hear a very slight whine but the problem has dimminished by 80%. I now drive my bike in fifth gear without having to skip though and go to sixth and has made my ride the enjoyable experience that it should be.
My thanks to all who posted about this problem and those who suggested Redline. I am a believer.
To those who still have the issue, do yourself a favor spend the few dollars for a quart, install it and ride in fifth as the bike was intended.
RE: Redline is the answer to the Whine
hmmmmm..ive tried amsoil (85-140) and redline heavy in my 07 ultra clatterbox.. both had little improvement after warming up, same clattering racket and 5th gear sounds horrendous. it take the fun out of this bike.face it....harleybotched up this"improvement".
rbt in mke
07 ultra
06 ultra (sold)
03 rkc (sold)
and a whole bunch more!
rbt in mke
07 ultra
06 ultra (sold)
03 rkc (sold)
>>>>There are several Redline Shockproof gear oils. I'm guessing you probably used 75w140. <<<<<
yes..i had tried the heavy shockproof.....the red goop!. some owners may have had better luck than i but like i said..afterits thoughly warmed up, its the same clattering/howling racket. a friend with an 07 ultra had the same results as mine.
maybe hd's new iso drive band-aid may calm things down....will wait and see.
rbt
rbt
Shockprook heavy comes in one viscosity. 75W/240. I did not think it was goopy at all. In fact I thought it was quit thin concidering the 75W rating. I did a quick test on the Syn3 I removed from the bike, by dropping a few drops of the Reline into a pool of the Syn3 in the drain pan and noticed the Redline sank quite rapidly to the bottom of the pan. It also seemed to have a much slippery feel in the finger test(subjective I know).
I also question the ISO drive fis for the spocket. In actuality you are applying a rubber damper on the spocket at the wheel. In my opinion that isa huge distance from the place where the problem exists. If you think of a simple lever , a small degree of disturbance will be magnified as you move farther away.However I am not an HD engineer, I would think they have this figured out, BUT they are also the ones who gave us the trannie issues.
ORIGINAL: rbtgold
rbt
rbt
