Starter gear gets stuck on clutch basket..... sometimes!
I have 2001 dyna twin cam 88. I just replaced the shift shaft seal and put everything back together. It starts no problem 8 out of 10 times, but sometimes the starter gear gets stuck on the clutch basket gears and wont retract. if I give it a little tap it go right back in. and ideas of how to solve this issue would be great.
SSBMX (07-18-2019)
I just came back from an 800 mile trip. the starter got hung up about 6 times the entire time. when it got stuck I would just put it in gear and rock it back and forth real quick, then it would retract and I could start it after that. the last 300 miles of the trip and probably 10-12 starts it hasn't don't it. so maybe problem solved.
masksqueeze
10-17-2008 08:56 AM
